1993 idi n/a throttle cutting out repeatedly when wide open... HELP!
Old Dec 6, 2011 | 07:28 PM
MeatWagon's Avatar
Default 1993 idi n/a throttle cutting out repeatedly when wide open... HELP!
Love this site and have learned tons from just bumping around here... I have a thread started on a fuel flow issue that I have not got a response to, so I figured I would post here as well... I realize that there are not supposed to be tech ?s here, but I am getting desperate. I don't want to spend $250 on an IPS and find out it is the IP. Does a new IP include the IPS on it?
I have a bitchin 1993 non turbo IDI A/T ambulance that has run great for 3 years, but is now having what I think is an electronic fuel relay problem. Almost 200k on her, runs and idles well (does take longer to start though...), but when you mash the throttle, fuel seems to be cutting out intermittently. At its worst it will throttle for 2 seconds and cut out for one and so on. I can drive it if I am light on the pedal and it does it FAR less. My tach also started going haywire about the same time... 0 at idle and will register under hard acceleration... Don't care about that so much unless they are related, though. I'm also running a bit hotter than usual, but suspect that has to do with the fuel flow. IPS? IP? I've been told there is no CPS in this engine. That is the extent of my abbreviation knowledge, so full part names would be appreciated please! HELP!
Reply With Quote Multi-Quote This Message Quick reply to this message
Old Dec 6, 2011 | 07:56 PM
cummins_guy's Avatar
with what you have explained, it sounds like a lift pump problem, these engine are all mechanical
PTC POWER, USA
2822 JUNIPER STREET
Fairfax, VA 22031
OFFICE# 703-641-0400 X 204
CELL# 571-230-8044
Q.C Engineer/Diesel head specialist
Michael Moxley
Old Dec 6, 2011 | 08:01 PM
MeatWagon's Avatar
hmmm... OK. At least that is one of the least expensive possibilities! I will check it out tomorrow. Any way to test it while still mounted? I thought that the engine would not even run if the lift pump fails...
Old Dec 9, 2011 | 09:39 PM
tomduelly's Avatar
You're over due for a new injection pump.
Old Dec 12, 2011 | 08:32 PM
MeatWagon's Avatar
that's what I was afraid of. Looks like I'm driving my miata or riding my xl500 until I have a couple days to knock it out! Thanks!
Old Dec 13, 2011 | 08:01 AM
globalwarmingcontributor's Avatar
hey bud.. i agree with tomduelly, its time for an injection pump, check out this place, Pensacola Fuel Injection | Worlds #1 Diesel Rebuilder - FORD 6.9L - 7.3L :: REBUILT FUEL INJECTION PUMPS..... they got pumps, injectors etc. hope this helps!
Old Dec 13, 2011 | 01:33 PM
MeatWagon's Avatar
damn. cheaper than my brother can get @ wholesale! thanks!
Old Dec 13, 2011 | 05:00 PM
anytime bud. good luck
Colbyflory
Aug 16, 2021 09:19 AM
