digital odometer and speedometer stopped working
Old Dec 4, 2011 | 04:04 PM
93 7.3L RIG WELDER's Avatar
Default digital odometer and speedometer stopped working
checked all fuses any other ideas. the cruis control stopped to. doesnt regester on the cluster panel and does not engage.
Old Dec 4, 2011 | 04:18 PM
DieselCrawler's Avatar
is your abs lamp on? the dash gets signal from the sensor on the top of the rear axle.
Old Dec 4, 2011 | 04:42 PM
yes the abs lamp is on to. also sometimes when it is wet out the front brakes will lock up if you touch them.
Old Dec 4, 2011 | 06:41 PM
your truck only has REAR abs. front tires will lock up still.
i would replace the speed sensor in the rear.
Old Dec 4, 2011 | 06:51 PM
I REPLACED THE REAR SENSOR THE ABS LIGHT WENT OFF. BUT IT DID NOT FIX THE DIG. ODOMETER OR THE SPEEDOMETER. THE PARTS GUY WAS SAYING THERE WAS ONE ON THE TRANSMISSION TO.
Old Dec 4, 2011 | 07:46 PM
you can look, but i doubt it. my 94 only has the rear sensor.
Old Dec 6, 2011 | 05:21 AM
blacksmokeaintbroke's Avatar
i have the same issues with mine and tried the same tricks with no help,but my 94 doesnt have but the 1 sensor on the rear axle which i replaced too,my neighbor is a ford diesel mechanic said its either in the dash or the ring in the rear axle in which the sensor you replaced picksup,but have not had time to try either to fix it yet hope that helps,but if you find the fix please let us know what was the problem
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
