starter mount broken????
Old Dec 4, 2011 | 01:25 AM
gijohn45's Avatar
Default starter mount broken????
My son went out to start my truck and heard a noise and nothing... he looked under the engine and found the starter just hanging there... the ring that the starter mounts to broke in half... is this part of the transmission or a piece that goes in between the tranny and the engine? its a solid piece that goes up and over the transmission and comes down about halfway on the drivers side....
Help/////
Attached Thumbnails starter mount broken????-330991_319137378097150_100000026702061_1398472_2009032031_o.jpg
Old Dec 4, 2011 | 01:26 AM
gijohn45's Avatar
the starter is on the left... the bolt you see is what bolts the starter to that ring.... its about an inch and half thick....
Old Dec 4, 2011 | 10:57 AM
fordornothing's Avatar
it looks like a seperate piece. you should be able to feel a line if it is.
Old Dec 4, 2011 | 11:43 AM
gijohn45's Avatar
it does look like a separate piece... just not sure what it would be called so I can get a new one...
Old Dec 4, 2011 | 12:21 PM
engine spacer maybe? i'd go to ford and have them look up a diagram on the computer. i know the OBS with a manual trans have that. but i don't have a clue what it would be called.
Old Dec 5, 2011 | 09:14 PM
CSIPSD's Avatar
Its the spacer ring... How the hell did you break that?
Your going to have to pull the trans to change it out. Make sure you get one from an Auto if your truck is an auto or a manual if its a manual.
Not hard of a swap, just time consuming.
Old Dec 6, 2011 | 06:32 PM
well mine is a manual and i don't have that. but i've never seen that on a SD, just the OBS manuals.
Old Dec 6, 2011 | 10:09 PM
CSIPSD's Avatar
Yes, you do have it... They are thinner on the manuals... but they are there none the less.
Old Dec 7, 2011 | 12:24 AM
Clark Kent's Avatar
I own a ZF6 7.3 and last month replaced the clutch and last week the starter. I can not recall there being a spacer around the starter hump on the ZF6. I also just went over my pictures and there's no small separation around the bell housing where it mates to the block.
Old Dec 7, 2011 | 07:18 PM
well i meant one that big. mine might be 10 ga. if that.
