6.7 cummins turbo question
Old Dec 2, 2011 | 07:39 PM
Hummin Cummins's Avatar
Default 6.7 cummins turbo question
my 2010 is overheating with a load. If I dive light footed with no trailer no problem. acts like a headgausket is going bad. Pushes antifreeze out of the over flow and air locks the cooling system.
EGR cooler is deleted , like I said it seems like a head gausket just starting to act up. Dealer said they have never replaced a head gausket. Thought mabey a turbo problem.
I know coolent does go to the turbo, but can that cause a problem like I am seeing?? Any way to test??
Old Dec 2, 2011 | 07:41 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
sounds exactly like my 08 done when my gasket blew.
Old Dec 2, 2011 | 08:04 PM
I really do think it is the head gausket. Just want to make sure the turbo cant cause the problem. I dont know anything about the turbo on the 6.7
Old Dec 2, 2011 | 08:21 PM
diesel pap's Avatar
i never saw a issue with the turbo like that. several cases with head gasket. when i done mine we had .012 taken off the head to make it flat.
Old Dec 3, 2011 | 08:35 AM
I know my truck got perty hot twice. What did your engine do. I am hoping I don't have head problems. I can drive my truck like normal if I keep my boost low. If I hook a traliler on and hit 30 psi, I am done.
Old Dec 3, 2011 | 09:11 AM
diesel pap's Avatar
mine was doing that. it got so bad before i done the gasket i had to pull the therm. out to get home after a truck pull with trailer behind me. my head was fine but as all of them need is redecked.
Old Dec 3, 2011 | 11:31 AM
coors_man_2005's Avatar
its head gasket im on number 3 right now i think this last time .20 was shaved off mine my head was in bad shape i went with o rings and went away from the stock gasket towards the end mine at idle would push water out
Old Dec 3, 2011 | 06:35 PM
Few more questions, Where can I get a repair manual for the 6.7 cummins?
Should a guy go with the factory head gausket. I know a guy that says he uses the stock cummins head gausket in his pulling truck with a 5.9 and it is easily in the 11 to 1200 hp range.
If not the factory gausket which one, where do I get it, why is it better?
Why did the gausket go bad in the first place. I pull heavy but no sled pulls or raceing. I had a really weak H&S tune my exaust temps never got above 1100 post turbo. And my truck was a dog compared to a ffew other guys trucks. Boost never went above 32.
I am wondering if I should put on a external wastgate like industrial injection has, to reduce drive pressure
Old Dec 3, 2011 | 06:54 PM
i know a guy that was still blowing them with an ewg he said he really didnt think it helped the 5.9 is different then the 6.7 the beteenn the higher cylinder pressures and drive pressure and i think there is a couple water jackets closer to the cylinder but anyways the 5.9s hold better i would go with studs and an aftermarket gasket i went through 3 factory gaskets and now i run whats in my sig
Old Dec 4, 2011 | 09:26 PM
dodgeram082500's Avatar
It sounds like a headgasket to me also ,and if I had it apart anyway I would not put a stock gasket back in it Lazarsmiths Vulcan are the way to go they are designed for the 6.7 ,but they can be used on other cummins engines also. Also, while I had it apart I'd 625 stud it no sense in buying twice anyhow just my .02
huntman7
8
Aug 28, 2015 05:42 PM
torg73
May 11, 2015 03:08 AM
Jan 28, 2015 03:30 AM
Oct 24, 2014 04:40 AM
4estlee
Oct 7, 2014 07:47 PM
