6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
hard start and rough running 6.5
Old Dec 1, 2011 | 07:25 PM
Ac6080's Avatar
Default hard start and rough running 6.5
ok so i just put new head gaskets and arp head studs on my truck because i had a blown head gasket. while i had the heads off i put a set of new marine injectors in. now when i go to start the truck i have to crank it for around 45 seconds before it will start, and when it finally does start it blows blue/white smoke out and runs rough and misses. it smokes at idle until it gets warm and it smokes even when it is warm and i get on the throttle. i bled all the injectors multiple times and still not sure what the problem could be.
Old Feb 13, 2012 | 11:10 AM
ebarresi5894's Avatar
did you look to see if the head was cracked?
marine injectors are junk i wouldnt have wasted my money
did you kink any of the injector lines?
Last edited by ebarresi5894; Feb 13, 2012 at 11:10 AM. Reason: Automerged Doublepost
Old Feb 15, 2012 | 07:14 PM
Jeff Bennett's Avatar
I would start with a compression test of your cylinders on the side the head gasket was replaced. This will help you narrow down the potential issue you are experiencing, otherwise you are just taking a stab in the dark.....
Old Feb 20, 2012 | 07:05 AM
great white's Avatar
Check your glow plug circuit....controller, glow plugs, wires, etc.
X2 on the marine injectors being essentially "a waste".....sorry.
bdbfam
Aug 31, 2015 09:06 PM
penley`
Jun 7, 2015 04:38 PM
ctjkelley
Jun 3, 2015 06:01 AM
petew
Jun 2, 2015 07:33 AM
ssmith.77
Jan 11, 2015 02:03 PM
