6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
help with codes
Old Nov 27, 2011 | 11:05 PM
shipps's Avatar
Default help with codes
i just checked my codes on my 94 6.5 turbo and im getting a 42 can anyone help please
Old Feb 13, 2012 | 11:15 AM
ebarresi5894's Avatar
DTC 42 - Fuel Temperature Circuit Low (High Temp)
Old Dec 10, 2012 | 06:01 PM
bobz71's Avatar
If you used the paperclip to jump terminals, what terminals did you jump, I have the '94 with the obd1
Old Dec 11, 2012 | 02:03 PM
Turbine Doc's Avatar
A & B to read codes in the diagnostic port with key on count blinks on dash of CEL for codes should start with 2 then 1 to let you diagnostics are activated, then a string of codes for the stored code, then back to 2-1 at end before starting the sequence all over again.
Old Dec 11, 2012 | 06:08 PM
bobz71's Avatar
Thank you, I was able Paper clip it and got a code 36, got any ideas what that refers to?
Old Dec 11, 2012 | 06:55 PM
Yup DTC 36 Injection pulse width too long which is set when battery voltage @ PMD is >10v with coolant temp @or above 68F and response time of injection time of the IP fuel solenoid >2.5 milliseconds.
All that means ?????? something in the IP solenoid monitoring circuit is unhappy.
I think but need to confirm it I work OBD-II mostly, but to clear code OBD-I disconnect battery then touch pos batt cable disconnected to negative disconnected.
Could be an intermittent code, or bad gnd to the PCM (pass side rear head stud on intake manifold), or bad IP fuel solenoid driver, or IP starting to get long in tooth, batteries getting weak and causing errant voltage, ECT possibly bad, IP solenoid bad and so on we have to work our way step by step to finger it out.
Lets start with a complete reset and go from there & see if it comes back.
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
