Died while gettin on highway
Old Nov 26, 2011 | 05:29 PM
ATX6132's Avatar
Default Died while gettin on highway
Truck was at a steady climb and about 65 it cut off and will not start...it has full crank and charge but won't turn on....just got heads done arps regulated fuel lines Ficm....still on side of road happened like 10 mins ago!! Codes from sct module p0232 p2290. 210-632-2095 Micah
Old Nov 26, 2011 | 07:01 PM
cummin_un_glued's Avatar
FormerVendor
p0232 is fuel pump secondary circuit high
p2290 is injector control pressure low (high pressure oil leak)
looks like ya might want to hook it up to a good scan tool and test the fuel pump on the frame and see if it will run (pressure test with a mechanical guage if it does run) then also watch the high pressure oil pressure from the icp sensor and see if its making a min of 500psi cranking, its possible you have a cut o-ring somewhere in the oil system
taweste
Aug 29, 2015 02:34 PM
Jct
Jun 23, 2015 07:52 PM
moose2j
Jun 21, 2015 12:36 AM
maier17
Apr 19, 2015 09:06 AM
Tyler_302
Oct 22, 2014 07:08 PM
