need help with replacing axle
Old Nov 26, 2011 | 03:47 PM
7.3lpowerstroker's Avatar
Default need help with replacing axle
So i have the 97 f250 and it has the dual eyebeams in the front and its terrible. i want to get a stright axle(dana 60?) and i wanted to know what i need to get to have everything match up. It currently has a 4in lift on it right now. can anyone help?
Old Nov 27, 2011 | 07:48 PM
fordornothing's Avatar
it bolts up. i had to drill for the sway bar mounts but that's it.
Old Nov 27, 2011 | 10:11 PM
would my leaf springs right now be enough for my lift size?
Old Nov 27, 2011 | 10:47 PM
chromehound's Avatar
Make sure the Dana 60 you get is out of a 95-97 F350 it makes the job easier from what I hear. Check your lift mfg to see what it says but I'm guessing it's the same for a 250 and 350 so you should be able to just swap the lift over to the 60.
Old Nov 28, 2011 | 12:07 AM
joebob3093's Avatar
Moderator
Im pretty sure you can use an axle out of a 92-97 F350. It just bolts right up. I bet if you use the springs you have now you will be closer to a 6 or 8in lift in the front.
Old Nov 28, 2011 | 06:01 PM
you will either need more lift in the back or less in the front. i helped my buddy take the lift off of his 94 250 and put it on his 95 350 and it dog asses bad.
Natenelson1
Jan 19, 2015 07:23 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
blakec
20
Oct 18, 2014 03:35 PM
