96 pump issue
Old Nov 24, 2011 | 09:39 PM
pitbull3825's Avatar
Default 96 pump issue
When installing 191 DV's I found out that the thing you drop it in that's held down by two nuts #6 was tig welded cause of a crack. Are they hard to replace? Can I pull it right out after removing the nuts? And where can I purchase a replacement??????
Old Nov 25, 2011 | 06:32 AM
cummin_un_glued's Avatar
FormerVendor
sounds like your talking about the barrel for the plunger and if so they run around $135 each from about any pump shop and the pump has to be completly torn down and the cam removed from it to replace it
can you take a pic of it and show us?
Old Nov 25, 2011 | 06:42 AM
Yup the barrel! Great I'll get my guy to pull it today but after pump shop labor and part I can just order a pump for 500 or so or try to weld the crack?????
Old Nov 25, 2011 | 11:12 AM
FormerVendor
Yep you will be less money to just buy another pump. I would be interested in your core pump
Old Nov 25, 2011 | 11:36 AM
With my luck I better keep the core pump! I spent yesterday pulling broken flex plate from my 93 F350 7.3 happy Thanksgiving
Old Nov 25, 2011 | 11:38 AM
FormerVendor
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
Cavnar
Sep 9, 2015 07:18 PM
HardLuck
Jun 24, 2015 08:04 AM
big tan snorkel
15
Dec 17, 2014 05:04 PM
veggyoilkid
Nov 10, 2014 12:39 PM
