Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
What have I done????
Old Nov 21, 2011 | 03:42 PM
JMM's Avatar
JMM
Default What have I done????
I was going through the steps to replace the door lock actuator on the passenger front door and got everything working from the lock perspective. One thing I did was to remove the bolt that holds the window track on the bottom (below the actuator) to allow me to move the actuator/latch assembly out of the door. Put it all back together and now the passenger side window goes down about 2" then gets stuck. Will go up no problem (at this point) but it will only go down the 2" or so. It looks like the window is in the track and I have tried to lower the window with the bolt loose (even loosened up the other two on the door to allow the track to move a bit) but no go.
What have I done???
Old Nov 21, 2011 | 09:59 PM
CSIPSD's Avatar
Not a clue... Might have jumpped track or something...
Old Nov 29, 2011 | 06:48 AM
JMM's Avatar
JMM
Ended up lubing the tracks and all the moving pieces in the door and all seems well - been ok for the last week or so - keeping my fingers crossed...
