Turning your EBPV into an Exhaust Brake
Old Nov 17, 2011 | 10:37 AM
The hosser's Avatar
Default Turning your EBPV into an Exhaust Brake
I found some really good directions online about how to turn your EBPV into an Exhaust brake. Check it out.. Hope i don’t get in trouble for sharing......
File Type: pdf
The hosser's Avatar
Let me know what you guys think?
Old Nov 17, 2011 | 05:25 PM
fordornothing's Avatar
that's the writeup i followed when i did mine. it works great! except the broken bolt on the manifold causing a nasty exhaust leak letting all the pressure out.
Old Nov 17, 2011 | 08:27 PM
CSIPSD's Avatar
Added to the sticky file...
Old Nov 18, 2011 | 01:53 PM
The hosser's Avatar
How bad was it? I really want to do this mod to my rig but i was not sure how reliable this source was and if anyone had done this yet. And just like every mod how bad is it for your truck.
Old Nov 19, 2011 | 08:27 PM
it's not to bad. the best part of the write up is they had all the radio shack PN's. that was very helpfull. the wires are even the same color. except the wire for the brake switch. i grabbed the wrong wire but i always just flip the switch to on. as far as engine safety. it's not bad. just don't accelerate with the EBPV closed. you could float a vave seat.
Old Nov 30, 2011 | 12:50 PM
The hosser's Avatar
How did you find the wire that is linked to the brake? I looked last night and can’t find any such thing off the master cylinder. It says that there is a green wire by the driver’s side of the master cylinder i the group of 4 marked "center high mount stop lamp feed". I can’t find it and do not really want to spend a ton of time finding a hot wire when the brakes are on. Do you have any idea fordornothing?
Old Nov 30, 2011 | 06:17 PM
there should be 4 wires on the fender side of the brake maste cylinder. they might be kinda tucked in there. on mine i didn't see anything saying stop center high mount or anything so i just grabbed the green. but like i said, i always just put the switch to on.
Old Dec 1, 2011 | 10:22 AM
The hosser's Avatar
Did you have any problems with the diodes?
Old Dec 1, 2011 | 07:25 PM
*knock on wood* i have not. if i did it agian i would just put a simple on/ off toggle to it. no brake switch or PCM control.
