7.3 RELAY 1997
Old Nov 17, 2011 | 09:06 AM
cowpoke's Avatar
Default 7.3 RELAY 1997
In the past we put 3 relays in . Someone told me to take that fancy cover off that covers fuel bowl & relay it holds too much heat. causing it to go bad.Is this true???????:Thanks:
Old Nov 17, 2011 | 09:28 AM
95powersmoker's Avatar
I don't think that is the cause...
Old Nov 17, 2011 | 10:17 AM
joebob3093's Avatar
Moderator
Sounds like bs to me. I took mine off because I was tired of taking it off all the time to work on it.
Old Nov 17, 2011 | 01:43 PM
2ndGen's Avatar
I cut slots in the 3 cap nuts so I could take them off with a screwdriver... Pretty fast now. How long are the relays lasting?
Old Nov 17, 2011 | 07:13 PM
cowpoke's Avatar
I also thought that might be bogus but took it off anyway. I did go through 2 in the last year.We are now putting in glow plugs .I have 226373 miles on it.
Old Nov 17, 2011 | 10:28 PM
crazycooter's Avatar
if you don't want to spend the money on the high priced gpr from napa, try a gpr109, which is the relay for an older idi, but they work just fine on the obs strokes too, and for around $25
Old Nov 18, 2011 | 01:43 AM
joebob3093's Avatar
Moderator
Or get the heavy duty stancore relay
Old Nov 18, 2011 | 01:48 AM
joebob3093's Avatar
Moderator
Old Nov 18, 2011 | 08:16 AM
CSIPSD's Avatar
I've never had an issue with the good old GPR 109... I've had the same one now for 3-4 years.
Old Nov 18, 2011 | 09:55 AM
cowpoke's Avatar
where do you get gpr 109 . I guess i have not herd of that one.??And thanks for reply
