07 5.9 Wobble when wheel left of center.
Old Nov 16, 2011 | 11:50 AM
CHEMMINS's Avatar
Default 07 5.9 Wobble when wheel left of center.
Ok, so I know what death wobble is, and this is not it. Just recently between 20-40 mph, the drivers side has a hell of a shake. Over 40 it goes to a grind feel.
No having a look, there is some small gouges on the brake rotor on the wheel side. Would that be enough to only shake when the steering wheel is left of center?
When I turn the wheel right of center, all the vibration goes away until I hit about 50 mph, then there is just the slight grind feel.
It is speed related, so I know it it something in the rotation.
Any ideas?
Old Nov 16, 2011 | 01:00 PM
dieseldude03's Avatar
Either axle u-joint or wheel bearing hub.
Old Nov 16, 2011 | 07:16 PM
CHEMMINS's Avatar
Nope.....found out what it was though. Well what it ended up being.....
8 sheared off wheel studs. Facked rotor, and brake pad. Rim toasted.......happened about 1/2 hr after I posted this.
Old Nov 17, 2011 | 08:05 AM
Um. Well I guess that would do it too!
Old Nov 17, 2011 | 08:58 AM
CHEMMINS's Avatar
Oh well...what can ya do. Good reason to upgrade the front brakes to police grade units.
SMatyac
Nov 11, 2014 12:49 PM
