whistle on drvrs side while driving but no whistle while stopped?????
Old Nov 10, 2011 | 05:00 PM
1trucker's Avatar
Default whistle on drvrs side while driving but no whistle while stopped?????
hey guys,
this thing is about to drive me nuts i have a 2003 ford f-350 super duty lariet with the 7.3 powerstroke with 214,000 miles on it, all stock no mods other than a super chip set to performance mode,but when it gets cold out i hear a whistling sound from the driverside as i drive and as i slow down and almost to a stop it quits,have checked all of drivetrain (thinking it might be a u-joint ) all is good, sounds more like a whistle than a sqweek,there is a electric fuel pump on the rail on the driver side was wondering if that could possibly be the culperat, eng runs and idle fine no problems there, regularly change fuel filter every other oil change at 10,000 milesm any help with this would be greatly appreciated thnks in advance.
Old Nov 10, 2011 | 07:18 PM
articfox's Avatar
i hate to say this bud but it may be a wheel hub assembly going mine squeaked like crazy till i got it fixed I HIGHLY RECOMMEND YOU GET THIS CHANGED IF THIS IS THE PROBLEM. take it to the shop it sounds like a wheel hub aslembly they aren't cheep to fix but its a must have
or whistle depends on the person take it into the shop they should be able to diagnose it for free
Old Nov 10, 2011 | 08:04 PM
Benedcit's Avatar
Hey what about the brakes on it, some have squealers on them?? to let you know there getting short.. just an idea
Old Nov 10, 2011 | 08:56 PM
1trucker's Avatar
brakes and berings are all new no squweel just a whistle
Old Nov 10, 2011 | 09:34 PM
articfox's Avatar
hmm no clue now
Old Nov 11, 2011 | 12:50 PM
The hosser's Avatar
Originally Posted by 1trucker
hey guys,
I had a similar problem. It turned out that my fuel pump was trying too push past a dirty filter. I thought I was golden because I just changed it. The sound was exactly as you explain it. Check the filter again I did and I ended up having to replace it even though I thought it was clean. I had filled up my tank with a bunch of crap and it was pushed right to that filter.
Old Dec 4, 2011 | 11:07 PM
1trucker's Avatar
ok thanks hosser will check it out and let ya know ..
Old Dec 8, 2011 | 11:56 AM
The hosser's Avatar
did you ever figure out the whistle?
Old Dec 8, 2011 | 01:13 PM
flathead jack's Avatar
tighten the hoses on the innercooler pipes at the y pipe
Old Dec 8, 2011 | 03:45 PM
The hosser's Avatar
thats what it was huh. wow with funny noises i guses the sky is the limit.
