more turbo whistle?
Old Nov 9, 2011 | 07:32 PM
timdale's Avatar
Default more turbo whistle?
Don't take this question too seriously! (More of a theoretical quest.) I have a 93 12v with a he351ve , 4" str. pipe exh. It does whistle with the actuator closed but shuts up when I open it. I love the whistle like a early 6.0. I know it has to do with number of turbine blades (he351 has 12, early 6.0 has 9) Would there be, in theory, a way to modify the turbine wheel to get more whistle? I would obviousy never attempt this on my own due to balance and performance issues, just curious if any turbo guru's had any thoughts.
Old Nov 10, 2011 | 10:58 AM
95powersmoker's Avatar
Not sure you will ever get a turbo whistle like the 6.0 in your cummins...
Old Nov 10, 2011 | 11:19 AM
Farmboy 2.0's Avatar
Put a metal tubed air intake pipe on and that will help it whistle more. Or so it seems like they do!
Old Nov 10, 2011 | 01:40 PM
EasternAggie's Avatar
Turbo off of a 6.0?
Old Nov 10, 2011 | 04:06 PM
jmac5058's Avatar
Dont Cummins turbos have a silencer ring on them thats easy to remove.
Old Nov 10, 2011 | 05:01 PM
turbo2332's Avatar
yep, a snap ring holds it in
Old Nov 10, 2011 | 05:17 PM
You do not wanna remove the silencer ring on the 6.7L vgt turbo. It will come apart the silencer ring helps keep the turbo together and machine the inside of the housing apart and them come apart.
Old Nov 10, 2011 | 06:32 PM
timdale's Avatar
Oops, forgot to mention I have a 4" homeade intake with an Amsoil filter and removed silencer so it howls pretty good under the hood but I like the exahaust whistle. I know the only way to get the 6.0 whistle is to have a 9 or 10 blade turbine made and I don't think that's gonna happen! If a reputable turbo shop did say a 5 or 10 deg. clip on every other blade it might work but I'm not about to ruin a good turbo for sound, that's why this wasn't a real serious question, just curious small talk
ps: The vgt doesn't use a snapring for the silencer, there's 3 pins you have to drill and punch out
Originally Posted by EasternAggie
Turbo off of a 6.0?
I thought the same thing, if you could somehow t-3 the exh housing
Old Nov 10, 2011 | 06:35 PM
Pretty much the only way to make your truck sound like a 6.oh would be buy a 6.oh...
You can get more turbo sound but a cummins will never sound, look or rattle like a powerstroke...
Old Nov 10, 2011 | 06:42 PM
timdale's Avatar
yup, I know but I'd kick my own as if I replaced my 5.9 with the 6.0! I did like my 01 7.3 though. The whistle has nothin to do with the motor though, it's all turbo. I know I could buy a diff. turbo that would whistle more but I like the vgt (runs cool, very quick boost, and exh brake). Like I said, just makin barstool talk, but I appreciate the comebacks.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
