97 f250 running ruf help
Old Nov 9, 2011 | 09:58 AM
fordboy10's Avatar
mad 97 f250 running ruf help
Started after the first cold spell would start truck and it would run fine the like 5 sec later it would start running bad so bad it would shake the whole truck and the check engine light comes on I am stuck on this one has plenty of oil checked that first but now I am stuck please. Help
Old Nov 9, 2011 | 06:57 PM
cummin_un_glued's Avatar
FormerVendor
shorted valve cover gasket, shorted from the glow plug wire to ground or an injector wire....it takes the ecm a few sec before it runs a self test and at that point when it sees the fault it kills that whole bank of injectors
dorman makes the kit now that comes with the gaskets and the injector harness pigtails, should fix ya right up just takes a lil time to do nothing major tho
Old Nov 9, 2011 | 10:33 PM
fordboy10's Avatar
Will have to look in to that but now truck will not even start Ford said it said it sounds like the pcm but I think there would be more problems if it was that right
Old Nov 9, 2011 | 11:07 PM
CSIPSD's Avatar
Check both of the UVC (under valve cover) harness... Drivers side and passanger side.
On the OBS there are two connectors on each side, each connector runs two injectors and two glow plugs.
Could be an IDM, but I doubt it at this point.
Old Nov 10, 2011 | 01:33 AM
Mr. Miyagi's Avatar
Is it blowing any smoke while cranking over?
Old Nov 10, 2011 | 10:51 PM
fordboy10's Avatar
Yes it is blowing smoke out sometimes black the a lot of blue white smoke
Thesinnest
Nov 6, 2015 10:40 AM
tim12valve
May 3, 2015 11:02 PM
carid
Diesel Bombers Sponsors
Jan 12, 2015 04:32 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
