2002 7.3 litre rough idle/no power
Old Nov 2, 2011 | 09:16 PM
Redman 24's Avatar
Default 2002 7.3 litre rough idle/no power
I have a 7.3 excursion. The filter plugged and the bypass check valve was stuck. All o-rings and seals started leaking profusely. The check valve body warped and the bowl float spring bent. I have changed out all the components and a whole new check valve assy. I cleaned out the bowl and installed a new filter and all compression seals at all lines. I replaced the drain valve as well as it would not seal. I test drove all speed ranges. Ran great, now will go to rough idle and no acceleration. If I shut down and restart the problem will go away. Have no idea because it is not constant. Please help.
Old Nov 2, 2011 | 10:45 PM
CSIPSD's Avatar
Check the fuel pressure.
Old Nov 3, 2011 | 02:15 AM
gradyc's Avatar
It could also be the HPOP on the way out.
Old Nov 3, 2011 | 08:24 PM
CSIPSD's Avatar
Doubtful...
Old Nov 4, 2011 | 03:05 PM
Redman 24's Avatar
It hasn't happen for a couple days, and gets about 50 miles a day. Could all that junk from the fuel filter body have been getting into the injectors?
Old Nov 9, 2011 | 02:59 PM
CMCA Swartzkrautheim's Avatar
If filter was that clogged remeber u have socks in the tank could b gettin cloged causin loss of fuel pressure, just replaced my pump damn thing still wouldn't run cleaned socks rollin like a bat outta hell
Old Nov 9, 2011 | 03:16 PM
Redman 24's Avatar
I hadn't heard of that. Where are they located. I will check that tonight. Thank you for the help.
Old Nov 9, 2011 | 03:22 PM
U have to drop the tank pull the sendingunit and its in a whit plastic housing I just left em out an putan inline filter between tank an frame mounted pump, I've got a couple pics of what they look like n what minehad in em lemme see if I can upload em
Old Nov 9, 2011 | 04:00 PM
Redman 24's Avatar
Great, thanks so much for the info.
Old Nov 9, 2011 | 04:11 PM
Hope it helps,any questions put em up an we shouldget answers for em
