looking at an 07.5 6.7...what to look for
Old Nov 1, 2011 | 06:08 PM
cumminsjp's Avatar
Default looking at an 07.5 6.7...what to look for
i found a nice 2500 6.7 truck with 87400 miles on it, has the H&S EGR delete, PDF delete, 4" Straight exhaust, Smarty SR programmer and already has a 3250 dd southbend clutch. what all should i look at on this truck when i go to check it out? i'm not familar with the 6.7's. hows the power compared to the 5.9 with the smarty?
thanks for any input!
justin
Old Nov 1, 2011 | 07:08 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
power is good. make sure the head gasket isnt leaking.
Old Nov 1, 2011 | 08:39 PM
coors_man_2005's Avatar
agree with diesel pap if the over flow tank is full prolly blown hg
Old Nov 1, 2011 | 09:07 PM
cumminsjp's Avatar
what makes the headgaskets blow so bad on these?
thanks for the replies!
justin
Old Nov 2, 2011 | 06:21 PM
i dont really know exactly but high cylinder pressures and drive pressures is the most common ones you hear some one else will chime in and break it down more
Old Nov 3, 2011 | 04:22 PM
dodgeram082500's Avatar
justin
More cylinder pressure due to larger bore/stroke has a big part in it
Old Nov 4, 2011 | 02:12 PM
cumminsjp's Avatar
hows building them up $$$ wise compared to the 5.9? also studs, can they been installed with the head on still? i know your supposed to run a tap down the block to make sure they bottom out and all that
Old Nov 4, 2011 | 09:23 PM
pretty simular in prices basicly the same motor more less and yes you can put studs w/o removing head
Old Nov 4, 2011 | 09:31 PM
diesel pap's Avatar
i like my vgt turbo but they cause more head gasket trouble.
brand97
Jul 5, 2015 10:36 PM
Adam65
Jan 9, 2015 11:50 PM
hondardr10
Ford Powerstroke 2011-Up 6.7L
Dec 28, 2014 04:33 PM
OkieWahoo
Dec 15, 2014 02:15 PM
4estlee
Oct 7, 2014 07:47 PM
