crappy mpg, suggestions?
Old Oct 31, 2011 | 07:36 PM
jdozer's Avatar
Default crappy mpg, suggestions?
So I took my 84 CUCV on a does trip last weekend, pulling my pop up. Got the same Mpg's as in the city. 12 Mpg at 55-65. Same on the return trip with out the camper. Trucks a 6.2 with a 3 speed th400, 3.08 gears. Any suggestions?
Camping trip, stupid phone....
Old Oct 31, 2011 | 08:36 PM
2MuchJunk's Avatar
Are you sure it has 3.08 gears? A 84 CUCV should have a lot lower gear. Check air filter and fuel filters first there the most common problem for bad fuel economy.
Old Oct 31, 2011 | 08:40 PM
jdozer's Avatar
I'll replace the fuel filter, it has a new air filter. The gears are 3.08, for economy, at least thats what i read on steel soldiers website.
Old Oct 31, 2011 | 08:45 PM
03Powerstroke's Avatar
what mpg do you normally get?
Old Oct 31, 2011 | 08:48 PM
jdozer's Avatar
It's been 12 Mpg in the city, I can live with that. i just expected better on the highway i guess
Old Oct 31, 2011 | 08:51 PM
it should be better
Old Oct 31, 2011 | 09:11 PM
jdozer's Avatar
I guess I'll start with the fuel filter, and check the IP timing
Old Nov 1, 2011 | 10:13 PM
2MuchJunk's Avatar
My 83 6.2 gets mid 20's with 4.10 gears you should do close to that. Does the truck blow any white smoke or chug?
Old Nov 2, 2011 | 01:49 PM
jdozer's Avatar
No smoke while running, a little during cold starts, and under a load/uphill of course, then not much. Doesnt chug, I did turn the pump up a little, being old military it was de-tuned a lot. Going to change the fuel filter next I guess
Ok, i replaced the fuel filter, cut open the old one. Full of ****. Looked like old leaves in there.
Checked the timing mark on the IP, its clocked slighty to the drivers side (advanced) maybe the width of 2 timing lines
Old Nov 5, 2011 | 12:44 AM
duallycc's Avatar
Doesn't the 6.2 have two fuel filters just behind the intake manifold??
