7.3 littter wont start
Old Oct 29, 2011 | 12:15 PM
NMKowboy's Avatar
Default 7.3 littter wont start
P0006 code poops up, i have new batteries and fuel pump, checked relays they seam to be working, NEED HELP ,PLease
Old Oct 29, 2011 | 05:40 PM
95powersmoker's Avatar
I don't know what that code is...
We need more information... Did it just all of a sudden not start... Miles... Mods... Anything you've done recently...
Old Oct 29, 2011 | 08:38 PM
teerin2deep's Avatar
if its turning over just wont start could be fuel bowl heater blowing i think fuse 22 underhood hard to see its blown , disconnect fuel bowl heater get it in the clear re fuse fire it up
Old Oct 30, 2011 | 11:02 PM
NMKowboy's Avatar
tearin2deep thanks ill try that
Hey 95 powersmoker, The truck 179950, replaced batteries celinoids and fuel pump , moved relays around to see if other codes would pop up, I would be driving and it would all of the sudden cut power to an idle for a few then pick back up, now it just turns over, its not pumping fuel up to filter on top of engine
now i got a P27FE code and the P006 coming up
Old Oct 30, 2011 | 11:29 PM
This would be a correct diagnosis if he is not getting a WTS light...
If you drain the fuel bowl, will the truck refill it? It sounds like you've narrowed it down to a fuel issue...
I still don't know either of those codes, what scanner are you using? Here are the codes our trucks have and I don't see either of those on the lists...
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 31, 2011 | 09:53 PM
NMKowboy's Avatar
got a new code reader let you know tomarrow how it goes.
Old Nov 2, 2011 | 11:13 PM
NMKowboy's Avatar
New code reader wont connect to truck , Chip programer still shows P006 code , turns over like it is going to fire, heater bowl is not filling, wait to start light comes on. Any ideas ? what to check next?
Old Nov 3, 2011 | 10:08 AM
There is no fuel in the fuel bowl?
Old Nov 3, 2011 | 08:16 PM
wyowelder's Avatar
check your oil those powerpokes have a murphy switch that kills them on low oil and then they wont start back up ( its similar to the dummy switches in a detroit for oil and coolant levels so the driver cant blow it up) give it a try if you havent already.
Old Nov 3, 2011 | 08:28 PM
CSIPSD's Avatar
Incorrect... There are no such switches on a 7.3 powerstroke.
