Turbo help
My turbo has been making a horrible grinding noise when holding consistent 6lbs or so when the oil gets warm, or at least thought it was the turbo. There wasn't really any play just very slight up and down not much at all though and no in and out. I ordered the rebuild kit from beans, rubuilt the turbo and still making the noise. The only spot that looked like it could have been rubbing was the backside of the impeller but it looks more like a machined spot than rubbing. I dont know what else it could be.
Looked totally fine fins looked good and no wear marks
Another thing I noticed to is after driving when I park I smell a burning rubber smell under the hood so I don't know if it is maybe a pulley bearing. The grinding noise is similar to like fan hitting the shroud
Last edited by 7.3Powerstroke95; Oct 23, 2011 at 05:11 PM. Reason: Automerged Doublepost
Haven't checked the water pump yet. Not sure if its the boost or amount of load or the rpms thats just the only consistency ive seen is when I hold it around 6. I can build up plenty of boost over 25 accelerating without any noise.
avatardvr
18
Aug 8, 2019 12:38 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
the sound might only occur at certain rpm instead of boost. i'd check all the pulley's
