6.7L Cummins Need Your Oppinion
Old Oct 20, 2011 | 08:40 PM
RanchhandTCR's Avatar
Default 6.7L Cummins Need Your Oppinion
Hi there.
This is for the workin class of trucks not the romp and stompers.
How does the 6.7L cummins do pullin? and are thet as good as the 5.9L and are they worth a damn at all.
We haul cattle up mountain passes all the time not up a 100 foot hills and we endure -20 to -40 degrees.
My next question is what fuel milage you gettin out of em and what the pros and cons.
Were lookin to replace our Ford 6.0L powerjoke. .
Be glade to hear you imput thanks guys.
Old Oct 20, 2011 | 08:50 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
my 6.7 does good towing. i tow alot in the summer. we sled pull and i pull a dual wheel tandem trailer with my 8000 lb sled pulling truck on it.
Old Oct 21, 2011 | 09:41 AM
baddodges's Avatar
Anything will tow better than the 6.0 ford.I tow in the mountains and no complaints the mileage isn't the best but after I did the deletes all that changed.I've owned both engines and love my 6.7
Old Oct 21, 2011 | 10:39 AM
coors_man_2005's Avatar
tow better then the 6.0 thats no kiddin there ........i pull my travel trailer that gross about 20 k no complaints right around 8-10 pulling empty 20 +
Old Oct 24, 2011 | 11:16 AM
vcustoms86's Avatar
My 6.7 is my pulling/ daily driver. With the exhaust brake and 6spd I wouldnt pull with anything else. I am going to a double disk clutch. I have done all the deletes with full 4 inch exhaust, AFE intake, and Mini Maxx programmer. The exhaust brake also helps warm up the motor in colder weather so in the SLV that would be very, very helpful to you. I pulled the same amount of hay with both of my trucks, little over 18K pounds, and the 6.7 pulled easier then my 24v. 6.7 just feels to have alot more low end grunt. Im getting 20-22 mpgs when empty.
Old Oct 25, 2011 | 08:51 AM
Hummin Cummins's Avatar
You will love the exhaust brake!!
I have 3.73 gears with the auto. Miss the manual trans.
If you go with a auto go with the 4.10 gears. My truck really strugles to get my 32 foot cattle trailer rolling with 16 cows. Once your going its fine that is why i wish i had 4.10's
Fuel milage rreally depends how fast you drive. I will get 20 with my dually at 55-60 probably 15-16 at 80. I also have a H&S with deletes. With my stock trailer hooked on I will get between 9-10 depending on wind
I just got rid of a 05 6.0 F350, that was a dog pulling anything. I am surprised you could make it up a mountain pulling a load of cattle.
Old Oct 25, 2011 | 09:52 AM
Sluggo's Avatar
if you go with the manual trans. plan on replacing the clutch, before long
Old Oct 26, 2011 | 10:27 PM
We got a running start up to the pass and then it was 2nd gear and pedal to the metal and one unhappy truck.
Old Oct 29, 2011 | 10:21 PM
Rail's Avatar
Default Pulls great
I have a 3500 with 4.10 grears, 6 speed auto, jake brake, dpf delete, H&S black maxx, stock tires, 5 inch back brake exhaust, air bags and Rancho XL9000's, i have pulled my neighbors 4 horse and camper fully loaded over the Rockies passing Semi's and others at will. My 24foot Well Cargo fully loaded tows like a dream, don't know it's there till we hit and incline and downhills with the jake brake and the transmission break are sweet. BTW 2008.
Old Oct 30, 2011 | 08:32 AM
Doing the deletes will be like your driving a totally different truck bud.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
