Cummins DPF
Old Oct 20, 2011 | 04:39 PM
jmac5058's Avatar
Default Cummins DPF
What year did Dodge go to a DPF?
Old Oct 20, 2011 | 07:09 PM
cummin_un_glued's Avatar
FormerVendor
jan 1 2007
Old Oct 20, 2011 | 07:20 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
07 is right. they were split that year. early 07 with the 5.9 and later with the 6.7 that has the dpf.
Old Oct 20, 2011 | 07:28 PM
jmac5058's Avatar
Thanks,I thought they did it a diffrfent way for a time.
Old Oct 30, 2011 | 12:26 PM
6.7lohmanb11's Avatar
i have 07 3500 6.7 nd my light came on that said power reduced see dealer... first started off saying exhaust filter 70% full then up to 100. what do i need to do because i can def tell power loss do i take it to dealership?
Old Oct 30, 2011 | 05:14 PM
coors_man_2005's Avatar
i would say just do the deletes and save a head ache later and you would be much happier
Old Oct 30, 2011 | 05:24 PM
Satanic Mechanic's Avatar
Do the deletes asap, your truck is in an engine derate mode so your losing power and its not good for your engine either.
Old Oct 31, 2011 | 06:06 PM
Default 6.7 (power reduced see dealer)
thanks Tony. so I shouldn't drive the truck at all until I get the tuner cause I did the research nd found the H&S Mini Maxx will clear all codes so I just ordered that and that should solve my problem. thanks again greatly appricated. Brandon
Old Oct 31, 2011 | 09:05 PM
be sure u have delete pipe also or exhaust
Old Oct 31, 2011 | 10:38 PM
Ya you really need to delete that POS DPF.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Oct 20, 2014 08:10 AM
