fuel pressure regulator
Old Oct 18, 2011 | 09:20 AM
emtyjugg's Avatar
Default fuel pressure regulator
I recently bought my first diesel. 2001 chev with duramax. My check engine light comes on then goes off after some mileage then comes back on . I have a code reader and it says pressure regulator 1 performance. Truck has 137xxx miles and chevy replaced the injectors at about 135xxx about 500 miles before I bought it. Previous owner spared no expense and took meticulous care of this truck. I'm no dummy when it come to mechanics. But this is my first diesel. what do I need to do?
Thanks Herb
Old Oct 22, 2011 | 02:49 PM
mcanfield's Avatar
search in the threads, there are numerous post on FPR
Hope this helps
Old Oct 23, 2011 | 12:45 PM
Ozz's Avatar
Ozz
I recenlty purchaed my 01 with 200K miles on her. I too got a code pO089 which is the fuel pressure regulator. I changed my fuel filter and it's gone. I started to run a qt of 2 stroke oil in my fuel plus diesel clean every tank full for added protection of the fuel system. I've yet to have any more codes. I did end up purchasing a new fuel pressure regulator off of ebay for 175 since the dealer price was 500 bucks for the same part
Old Oct 23, 2011 | 02:19 PM
Blaine's Avatar
Thanks Herb
Does your truck have a "lope" at idle(revs up and down)?
Old Oct 23, 2011 | 02:57 PM
Ozz's Avatar
Ozz
Funny you ask, yes it did. I swapped out fuel filters and ended up needing a new WIF sensor, the sensor on the bottom of the fuel filter. Once I changed out the sensor, primed the fuel filter, she ran as good as new with no lope in the idle.
I did get a programer to read the codes and to use if for econo-mode. I did see the code come back one time. I cleared it have yet to see the code. That being said, I purchased a fuel pressure regulator for futre repairs.
Good luck and keep us informed on your resutls
Old Nov 5, 2011 | 08:02 AM
johnnydingding's Avatar
Any update on your repairs? My 03 Duramax has been throwing out P0090 code and intermitten crank but no-start. The code has come on ramdomly but the intermitten no-start seems to happen in the morning when it's cold (about 35 dgrees).
Usually when the no-start occurrs, I put my code reader in, clear the P0090 code and it starts.
A few days ago, I replaced the FPR but I've had the P0090 code pop back up and so far have had another no-start. I've read somewhere that possibly the ECM is to blame for the code and hopefully the no-start problem.
I have an appt on Monday to have my computer re-flashed to try to remedy the problem.
Does anyone else have any suggestions?
Old Nov 25, 2011 | 01:25 PM
41merrell's Avatar
What's the status after the reflash?
Old Nov 25, 2011 | 01:34 PM
Took my truck to a tech for ECM reflash. Tech told me there were no updates available for my truck and reflashing would be a waste of $$ and time.
Made a more in-depth search of the wire harness that runs behind the alternator to the bail connectors. Found a partially damaged wire behind the alternator. The insulation was visually rubbed thin although I couldn't see any exposed strands of wire. Taped it up and placed a piece of rubber under the harness and zipped tied it back down.
Keepin my fingers crossed that this was the root of my problem.
Old Dec 6, 2011 | 08:45 PM
emtyjugg's Avatar
Yes, and sometimes it will lunge from a stop as I step on the gas. I started running chevron and added lucas it seemed to help but still coming off and on.
Old Dec 6, 2011 | 09:35 PM
Ozz's Avatar
Ozz
Keep us informed on the results of your repair. Good info for thoes who search
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
19Samahi72
Jan 26, 2015 10:55 AM
