clutch is going south
Old Oct 15, 2011 | 09:09 PM
Sluggo's Avatar
Default clutch is going south
it sure dosen't take much to fry the stock clutch. I was looking at getting bigger nozzles or upgraded turbo. But now I get to buy a clutch With what few mods I have, I sure never thought the clutch would be slipping allready. It's not to bad yet, but if i romp on it very hard..it slips 39,000 mile on truck is all I have. When I bought this pickup it said the manual trans. trucks had 30hp less the the same pickup with a auto trans. If Dodge knew the clutch was weak. Why didn't they put in a better clutch, instead of de-rate the engine?? I wonder what the HP rating is on the stock clutch, I doubt if I'm making much over 375hp I'm 50+ yrs old, I haven't done anything stuipid or abused the clutch pos
Old Oct 15, 2011 | 09:31 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have saw some plain stock trucks clutch fail.
Old Oct 15, 2011 | 10:36 PM
Sluggo's Avatar
how are the auto trans holding up with mods done? I see on here, alot of people saying get Gauges if you upgrade...I think if u have manual trans... it should be.. get a diffrent Cultch before upgrades
Old Oct 15, 2011 | 10:44 PM
diesel pap's Avatar
with the g-56 that is true. my 08 is auto. every tuner i sell somebody with a g-56 tranny gets warned about the clutch. after you upgrade the clutch they do a good job.
Old Oct 15, 2011 | 10:59 PM
Sluggo's Avatar
ya maybe i got greedy the smarty said don't go over 90hp setting with stock clutch..i ran 130hp setting, clutch started slipping & turbo made all kinds of bad noises at 34psi boost. do these stock turbos have a wastegate of sorts? thats the noise it sounds like, and it sounds like the vanes are hammering closed. I set it back to 90hp the bad sounds have gone away but the clutch still slips
Old Oct 15, 2011 | 11:06 PM
coors_man_2005's Avatar
is it a rattle noise? i smoked my factory clutch under 20k but i kinda made it go cause it pissed me off so i held it till it wouldnt hardly pull its self also i would say head studs pretty quick
Old Oct 16, 2011 | 12:04 AM
Sluggo's Avatar
coors man, i think your on to something. it probaly was my clutch making all the racket, not the turbo. I've never owned anything before that would smoke the clutch in 4th gear Can u answer a ?? for me.. what is the highest safe psi that the turbo(stock) in my pickup can make....I don't have real gauges..just the Edge W/A is says I'm making 34psi do's that sound right?
Thanks for the good price on the clutch Tony, hopefully it will be awhile before I can smoke it
Old Oct 16, 2011 | 09:43 AM
baddodges's Avatar
I've got the same problem with my truck looking at the vallair clutch. Heard good things about them.
Old Oct 16, 2011 | 01:21 PM
Sluggo's Avatar
My clutch went to South Bend should be all better now
Old Oct 17, 2011 | 08:22 PM
south bend dd is the way to go had the single but it didnt make it so went double disk......... about the rattle i was thinkin maybe injector rattle is what you was hearing ...............when i had my stock turbo i could bounce it off 40 but hold 36-38 not saying thats good with the drive pressures though
