smoke problem help!
i have a 2000 its smoke horrble at idle its fuel smoke iv put 1 new injector in passenger side an all new orings on the other three the driver side has 2 new injectors i didnt put orings on the two of the injectors on driver side...iv cleaned irp an icp is good the truck idle like a obs truck now im confused an need help???..the truck just has a col air right now an an ebpv delete it only boost like 11 psi i did have dp an it would only hit like 20.
Well the boost is low. Probably a boost leak...
What injectors have you put in there? Where did you get them? You didn't put o-rings on the 2 on the drivers side? The new ones? What did you put on them?
There is alot more info you could supply us with which might help us out..
Timing is controlled by the pcm so that isn't going to be the issue..
got the injectors from beans an the o-ring kits i didnt to injector oring kits to do driver side so i left them....after i cleaned the ipr though it idles like an ods truck they are all stock ad injectors to by the way...truck still starts hard even after its warmed up
the smoke is grayish just does it at an idle i replaced the ipr that helped with way it was run but you can feel the miss in it....it my only rig i didnt have any more injector oring kits to do last two injectorst on driver side so i stuck them back in...the smoke is all raw fuel though motor dosent have knock but you can feel the miss in it..its deftly driver side cause i have up pipe leak on driverside an thats were all smoke is comin from.
burndiesel
10
Feb 7, 2023 01:15 AM
mattshow123
14
Mar 12, 2018 01:41 PM
gagemotors
Jun 9, 2015 04:24 AM
