Quadzilla stealth 2 & fuse location
Old Oct 4, 2011 | 09:43 PM
Ozz's Avatar
Ozz
Default Quadzilla stealth 2 & fuse location
I recenlty purchased a Quazilla Stealth 2 chip. The instructions clearly say to remove the RDO 1, RAP 2 and the SEO IGN fuses (3) that are inerior fuse removal.
I can not find any "interior fuses". I found the electrical box that contains the fuses under the hood next to the drivers side battery. I could only find the RAP 2 fuse in that box.
Has anyone here used the stealth 2 quadzilla and if so, where did you pull the fuses from...interior fuses??? I"m frustrated
Old Oct 5, 2011 | 02:04 PM
2500HeavyDuty's Avatar
you have to open the door and they will be on the A frame on the side of the dash you can only see when the door is open. there is a pannel there
Old Oct 5, 2011 | 02:31 PM
Ozz's Avatar
Ozz
kicker panel?
Old Oct 6, 2011 | 05:42 AM
gordons01's Avatar
open the drivers door...look on the side of the dash there is a panel there. i have the same tuner
Old Oct 6, 2011 | 09:54 AM
Ozz's Avatar
Ozz
Thanks for the help!
Now, which tune is the best for MPG on the HWY?
I was amazed how much power the 135 setting produced! I love that power, however, I purchased the chip for better MPG. I drive 40 miles to and fom work, so I want to squeeze as much out of her on the HWY. I currently have set my chip to the economy mode.
Aug 13, 2015 10:10 AM
stone9291
Jul 23, 2015 05:13 PM
david.burger
May 30, 2015 08:25 AM
Nov 7, 2014 05:40 PM
Altonlee
Oct 1, 2014 04:58 PM
