2000 f350 oil leak help!!
hi im new to this
but i have a 2000 7.3 with a hypermax turbo i just did the o rings in the pedistal bc i had a massive oil leak now after replaceing i still have a leak coming from the same spott on the back on the engine between the starter and the pan. the valley is dry now after doing the o rings, what should start to check now?
it only leaks when the truck is running some times a constant drip and other times just drip. please help me!!
thanks
Cyle
it only leaks when the truck is running some times a constant drip and other times just drip. please help me!!thanks
Cyle
yes there is not oil comming from the pedistal or turbo
the hypermax turbo and pedistall is two parts and the pedistal orings are seated differently in the pedistal. its not leaking at all from them or the oil suppy line or the return line .
check and see if the oil is coming from the dipstick where it goes into the pan, thats where mine is leaking... thought it was from higher up until i cleaned everything off and left it running over my oil pit
pro graphic solutions
Feb 10, 2015 03:48 PM
