4" lift
Old Sep 28, 2011 | 01:58 PM
94cummins12v's Avatar
Default 4" lift
ok guys the custom lift i built for my ford cummins aint cutting it to bouncy what would be a cheaper 4" lift soft ride for an extremely heavy truck cummins motor and 500lb front bumper?
Old Sep 28, 2011 | 02:15 PM
joebob3093's Avatar
Moderator
Default Re: 4" lift
Your best ride would be a D60 with an RSK and SD springs but that's not real cheap.
Old Sep 28, 2011 | 02:16 PM
03Powerstroke's Avatar
im not sure, check summitracing.com btw thats a realy nice truck!!!!!
Old Sep 28, 2011 | 07:25 PM
thanks i found a kit threw rough country that is $600 for everything i think i may try unless somewone else has any more input
well the suspension i am actually running is a dodge dana 60 that i converted from a coil over to th eleaf springs but i ended up using f250 springs with an addaleaf and i additionally added 3 more leafs to the combination which is to bouncy
Last edited by 94cummins12v; Sep 28, 2011 at 07:25 PM. Reason: Automerged Doublepost
Old Sep 28, 2011 | 10:44 PM
95powersmoker's Avatar
I think a 600 dollar rough country lift kit isn't going to be exactly a smooth ride... There are some things out there that you get what you pay for and I would classify a lift as one of those things...
Old Sep 29, 2011 | 03:25 AM
joebob3093's Avatar
Moderator
Default Re: 4" lift
If your running a D60 go to sky manufacturings website and order an RSK and find a set of 350 springs to go under it.
Old Sep 29, 2011 | 04:14 PM
RSK kit?
Old Sep 29, 2011 | 04:37 PM
godblessmud's Avatar
Rough Country will get you the opposite of a nice ride. When it comes to lifts you really do get what you pay for, a 600 lift will get you stock shocks just extended, blocks for the rear (read axle wrap!). Check out Skyjackers stage II kits. I am running a 6" all spring "soft ride" kit on my ford. it set me bac 1300 4 years ago. All new lift springs front and rear, nitro charged shocks it rides better than most stock new trucks.
Old Sep 29, 2011 | 06:19 PM
joebob3093's Avatar
Moderator
reverse shackle kit
Old Sep 30, 2011 | 03:17 PM
ok got ya im not looking to do anything for the rear soft rides are junk in the rear on a 1 ton used for towing and axle wrap aint an issue with traction bars just want them in the front as for shocks already got nitros so shocks arent needed
