03 CR wastegate mod with boost fooler?
Old Sep 27, 2011 | 10:47 AM
BLACKSMOKEMOAN's Avatar
Default 03 CR wastegate mod with boost fooler?
I was looking at a boost fooler and it says the wastegate will need to be modified in order to get more boost out of a he341 equipped 03-04 truck. Can someone tell me the procedure? You don't plug the wastegate do you? Do I even need a boost fooler or is it just to cover up codes in the dash?
Old Sep 27, 2011 | 10:55 AM
GuyWithA24Valve's Avatar
The computer will defuel at a set boost level. The boost fooler just interrupts that signal so that the computer keeps fueling. If your truck is 100% stock, you might want some sort of fueling modification or else the extra boost wont do much for ya
Old Sep 27, 2011 | 04:55 PM
It is something I want to do when I add a smarty s06 pod. Will this add enough fuel? or we talking injectors?
Old Sep 29, 2011 | 08:32 PM
cerberus60's Avatar
The Smarty will take care of over boost codes until 45 psi. To get more boost you need to either crimp the WG boost reference hose or add a boost fooler to it. Adjust the set screw in on the boost fooler to raise boost.
Old Sep 29, 2011 | 09:09 PM
So if I clamp the reference hose it would be "plugged" right? But if i get boost fooler i can control the waste gate?
Old Sep 29, 2011 | 09:12 PM
cerberus60's Avatar
Sorry, wrong term. Boost elbow. Yes, with a boost elbow you can control the max boost before the WG opens.
Old Dec 7, 2012 | 07:41 PM
03CumminsNoob's Avatar
I have a 03 cummins with a Edge Juice w/attitude and was wondering do i need a boost fooler or with me setting max boost to 35psi on programer allow more?
|WYG|SS
Jul 26, 2015 11:18 AM
RexShoppe
Price Quote - Request A Price
Jun 16, 2015 02:48 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
somarillw
Dec 4, 2014 12:37 AM
