1996 chevy 6.5 turbo diesel loses power
Old Sep 18, 2011 | 09:36 PM
mrmarkman's Avatar
Default 1996 chevy 6.5 turbo diesel loses power
hi. i have a 96 k-2500 4x4 auto. replaced injector pump 30.000 miles ago. fuel tank and lines 1000 miles ago lift pump 1000 miles ago. new fuel filters. new pmd. 6 foot harness with aluminum insulator. mounted under front headlight. last october truck lost power out of the blue was driving and all of a sudden felt like was running out of gas and put foot on gas pedal and got nothing. put in neutral and it would rev no problem, back to drive nothing would not budge. pulled truck out in july to go to mechanic and it started and drove about 600 miles before same problem and i parked it again. mechaNIC HAS NO IDEA WHAT TO CHECK FOR. ANYONE HAD THESE SYMPTOMS? HELP. THANKS, MARK IN CONNECTICUT.
Old Oct 17, 2011 | 09:39 AM
ebarresi5894's Avatar
check the OPS. it can intermit power to the lift pump. if the ops is good, it could be the oil pump.
only reason im saying this is because my friend has a 6.5 that would do the same thing and he replaced the ops and it would still die, then he put an oil pressure tester and it was reading about 20psi.
Old Oct 22, 2011 | 06:12 AM
6.5 Man's Avatar
Default Fuel lines problem!
Hello,
This might be due to fuel lines running in between you engine block, I had the same problem wouldn't go over 2 or 3 RPM found out the line had dry rot.
Probably the on going to the tee line run off, I went and found the gel lines these don't dry-rot, then I placed heat resistance cover over all of them to prevent the heat from drying them out!
Summit racing is where I found the hose & heat cover... might try this!
Most people where telling me it was IP or PDM then I did this & everything is fine!
Old Oct 22, 2011 | 10:50 PM
396T's Avatar
I have a similar problem. I installed a boost gauge to see what was going on with my turbo and foud it was crapping out. The wastegate would open and i would lose all boost. The first solution, i ziptied the wastegate close, then i fabbed up a breacket to replace the wastegate and make it a fixed wastegate. Helped out alot. Try getting the truck up to g
About 60, and listen to the exhaust tone, if it gets deeper, your wastegate may be dumping.
Brclouse
Nov 18, 2015 08:44 AM
glasspack
Jul 29, 2015 11:04 AM
May 10, 2015 10:57 PM
krg3590
Mar 15, 2015 08:57 AM
Snoobly
Dec 11, 2014 11:59 AM
