1994 idi turbo spool
Old Sep 18, 2011 | 08:49 PM
Kwilliams's Avatar
Default 1994 idi turbo spool
Ok,so I have a 1994 turbo idi with a Garrett a r .70 an it's slow to spool I can get 13psi when it opens up but what would be some
Things that's speed up the lag? I am goin to get a cold air intake what's some good ones? An I'm putting 6inch stacks on it in about a week straight pipe sliverline kit.
Old Sep 20, 2011 | 05:47 PM
DieselCrawler's Avatar
is it the factory turbo unit?
Old Sep 20, 2011 | 08:26 PM
Kwilliams's Avatar
No it isn't
Old Sep 21, 2011 | 04:53 AM
no help for ya then, i only know **** about the kits....
Old Sep 21, 2011 | 07:41 AM
Kwilliams's Avatar
I lied, I just checked an that is the stock turbo.
Old Sep 21, 2011 | 04:54 PM
ok, you have the factory turbo which is made my ATS. banks sells a better downpipe for the stock unit like you have, costs 90 bucks or so. get it. also get rid of the big cast aluminum heat sink they call a air filter housing and make up your own cold air setup, just be sure to run the CDR tube back into the new intake for the crank case gasses.
Old Sep 21, 2011 | 07:33 PM
Kwilliams's Avatar
Alright thanks, I was goin todo what you said an just make my own air filter the stock one isn't very good! Well thanks for the help bro! Now do you or do you know someone who runs those stage 1 injectors? I was wondering how much improvement they made.
Old Sep 21, 2011 | 07:57 PM
expect fuel mileage to go way down. they do make power, but also they make smoke at idle and poor mileage.
find a good injector shop and just get a set of PRESSURE MATCHED bb code injectors.
Old Sep 21, 2011 | 07:58 PM
Kwilliams's Avatar
Alright thanks I figured they'd be bad for fuel milage.
GarrettEvan
Jan 30, 2016 05:39 PM
Devon7.3
Sep 27, 2015 10:35 PM
mrmuckshifter
Mar 24, 2015 01:48 PM
mrmuckshifter
Mar 24, 2015 01:47 PM
schearer350
Feb 12, 2015 12:27 AM
