Front Axle
Old Sep 16, 2011 | 08:44 PM
Ned'ers's Avatar
Default Front Axle
I got a question. Will a front axle from a 78 F350 fit a 95 F250 7.3?
Old Sep 16, 2011 | 09:16 PM
fordornothing's Avatar
possible, i'd try and find one from a 94- 97 f350. make sure it's complete with everything you need. i did this on my old 94 250 and i only had to drill the frame for the sway bar brackets.
Old Sep 16, 2011 | 09:53 PM
PHPDiesel's Avatar
Sponsor
Not without a LOT of work.
The spring perches are closer together on the older axle and you will run into issues especially on the left (driver's) side.
Old Sep 16, 2011 | 10:23 PM
Ned'ers's Avatar
Thanks, i didnt think it would, been looking for a f350 axle but there pricey.
Old Sep 16, 2011 | 11:59 PM
yeah the d60's aren't cheap. even a good used one is pretty expensive. i'm assuming you don't like that IFS you have?
Old Sep 18, 2011 | 02:37 AM
Ned'ers's Avatar
Well i changed the rear gearing and iam trying to match the front except i cant find a gear set for the IFS. So, i can either by a IFS with the right gear ($200-300) or find a Dana 60 with the right gear ($1000-1500). Iam thinking of swapping the gear, pinion, shims from a used IFS.
Old Sep 18, 2011 | 03:55 AM
Captain Call's Avatar
Where is the truck for that axle? 1979 is the first year for the 1 ton 4x4. I would give my left ******** for another 1979 F-350 4x4. I still have the original brochure for the 79 fords.
Old Sep 18, 2011 | 11:56 AM
oh makes sense. what gears did you go to?
Old Sep 18, 2011 | 11:38 PM
Ned'ers's Avatar
Just the axle was on craigslist.
I changed to 3.55's
Old Sep 21, 2011 | 12:08 AM
zcarmark's Avatar
What gear ratio did you have. I'm wanting to change my 3:55s for some 4:10s. Maybe a trade could work if shipping isn't to bad
