church bus
Old Sep 13, 2011 | 09:59 PM
linemanron's Avatar
Default church bus
I have a 1983 international 6.9 that will not idle back. Took pump off and had rebuilt. Shop could not find anything causing problem but rebuilt anyway. Low idle controls checked out and are working fine on pump. There is a sensor behind water pump and in front of timing gear with the same wiring harness as the idle controls on pump, is this an idle control also?
Old Sep 14, 2011 | 04:51 AM
DieselCrawler's Avatar
that is your temp seonsor for cold advance and high idle.
Old Sep 14, 2011 | 06:31 AM
linemanron's Avatar
so if that seonsor was bad it would let the idle control on throdle push out and speed up
Old Sep 14, 2011 | 07:36 PM
easy way to test is to unhook the cold idle solinoid. it is on the pass side of the pump, right next to the thermostat housing. it pushes on the throttle.
mooney_ag
12
Aug 31, 2015 11:17 AM
May 5, 2015 01:20 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
Omingnome
Oct 20, 2014 12:25 PM
