7.3 NO START
Old Sep 1, 2011 | 07:11 AM
7.3STROKER01's Avatar
Default 7.3 NO START
Parked my truck in my driveway last night, mowed my grass. got in my truck to leave and no start, just crank and crank. checked every possiable fuse/relay, all good. wait to start light does not come on now either? any ideas
Old Sep 1, 2011 | 08:13 AM
06 RAM's Avatar
injector pumps usually fail at around 100,000 miles in 7.3
Old Sep 1, 2011 | 08:32 PM
Relized my first post was a little vague, its a2001 powerstroke, i have fuel in filter bowl, no start, checked all fuses and relays. i have no wait to start light and no rpms while cranking? any ideas?
Old Sep 1, 2011 | 10:16 PM
farmerdude's Avatar
Cam sensor, maybe?
Old Sep 2, 2011 | 10:05 PM
RanchhandTCR's Avatar
If your not reading any RPMS then your computer wont be able to tell you truck is running at then750 rpm to start the injectors. you can try replacing your crank sensor located underneath the truck in the front left
Old Sep 3, 2011 | 10:49 AM
Thanks for the info, but unfortunetly I found out my pcm is brain dead.
Old Sep 4, 2011 | 10:44 AM
CSIPSD's Avatar
There are no "Injector pumps" on a 7.3... And there is very little that fails around 100k on a PSD...
Do you have a chip installed?
Have you checked the PCM power fuse under the hood?
Old Sep 6, 2011 | 08:59 AM
the first thing was to check all the fuses everywhere, and then i pulled the chip out. had a good friend who works at a ford dealer stop on his way home with the scanner and his repair manual, after some testing and the scanner not connecting, the pcm is no good.
Old Sep 6, 2011 | 09:57 AM
CSIPSD's Avatar
Did you remove the chip with the key in? That will cook a PCM every time.
Also, make sure your chip is well secured once you get a new PCM.
Old Sep 6, 2011 | 10:19 AM
yea the key was out and battery was unhooked. and this was after the fact it didnt start.
