using used oil
Old Sep 1, 2011 | 12:48 AM
907stroker's Avatar
Default using used oil
ive heard of alot of people using there used oil in the fuel tank.. has anyone else done this? if so, what is a safe amount, and what are the effects if any
Old Sep 1, 2011 | 07:49 AM
nydiver's Avatar
DO NOT POUR YOUR USED MOTOR OIL IN THE TANK. That oil has metal particles in it. You want to use FILTERED veggie oil from a restaurant then go for it, 20-30% cooking oil to 70-80% diesel will be fine in most areas. You do need to let the oil set for a while (2-3 months) to get it to separate oil from water, that or you need to heat the oil up to over 212F to boil out the water, then seal the boil pot and let it cool without moisture reintroducing itself into the oil as it cools. You do not need to get fancy unless you want to burn straight veggie oil.
Old Sep 1, 2011 | 09:18 AM
CSIPSD's Avatar
There are lots of people using used motor oil cut with gas...
Not running that crap thru my injectors...
Old Sep 1, 2011 | 12:02 PM
907stroker's Avatar
no way on the veggie oil, im not into that.... and i was just wondering if anyone has done anything with used oil.. i know its a bad idea to do it straight
i do want to look at getting a new hpop. but dont remember all the good websites
Old Sep 1, 2011 | 10:30 PM
gradyc's Avatar
I have been using some used oil in the fuel in our 92 cummins. I have a centrifuge filter system and filter it through for several hours to make sure there are no particles left to clog the filter or wear the IP and injectors. I don't know what a good amount to use is. I have just been pouring some in with a tank of fuel.
Old Sep 4, 2011 | 07:17 PM
bowietrucking's Avatar
seems like a waste of time and not really any significant gains to me. just sayen.
Old Sep 5, 2011 | 11:32 AM
gradyc's Avatar
There is not much time involved with my system. All I have to do is pour the oil into my filter system and turn it on, then walk away for a few hours while it does the work. I have over 200 gallons that has collected over time so the fuel cost that it will save is significant.
Old Sep 6, 2011 | 10:28 PM
WILE's Avatar
Default Used Oil being used in diesel fuel
Years ago and I mean years ago I remember there was a large Truck Fleet that ran a pressure oil line off to the fuel tank using a metered flow and every so many miles they would check the crankcase dip stick and add as many quarts of oil as needed. They would change the filter every so often and not change the oil only add. It was figured to save money on fuel as well as save on oil changes. Not sure how it worked out with all the changes in this world I lost track of the Fleet. Just some old history from about 40 years ago.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
