06 5.9L Down cylinder?
Old Aug 30, 2011 | 04:59 PM
06 RAM's Avatar
Default 06 5.9L Down cylinder?
When you take off the oil cap there is an inordinate amount of back pressure. I was told by one mechanic that it must be a broken ring. Also it is idling rough and there is alot of crankcase pressure venting through the tube. Is there anything else that would cause this?
180,000 miles.
Old Aug 30, 2011 | 06:44 PM
wildbill's Avatar
Any mods??
Old Aug 31, 2011 | 11:04 AM
06 RAM's Avatar
None that I know of. I was wondering if the CAT is partially clogged if it could cause this issue? I bought the truck in July
Old Sep 12, 2011 | 02:58 PM
06 RAM's Avatar
Still in need of advice. If it would definitely be a broken ring where is the best place to purchase a master rebuild kit?
Old Sep 12, 2011 | 06:53 PM
cummin_un_glued's Avatar
FormerVendor
do a compression test and that will tell you if you have a broken ring
Old Sep 12, 2011 | 09:16 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have seen several trucks with scored cyl. and or pistons. we had 3 or 4 trucks this summer in the shop.
Old Sep 13, 2011 | 09:10 PM
FormerVendor
like tony said we have seen some also...btw the CR pistons have the top ring closer to the top and i belive that is leading to more broken rings then on the older engines
Old Sep 13, 2011 | 11:39 PM
diesel pap's Avatar
i test drove a 06 after the guys installed gauges in a 06. the egts were pretty high. no tuner was on the truck. the ecm flash on these stock had some fuel. they run pretty good stock.
Old Sep 14, 2011 | 07:31 PM
FormerVendor
yeah then add on top of that a leaking injector and you get some really hot cylinders and without EGT if you may not ever know untill its too late
jbxyz
Chevy/GMC Duramax 01-04 LB7
10
Apr 24, 2015 07:19 PM
Kennyw250
Jan 14, 2015 07:47 PM
Oct 31, 2014 08:10 AM
Omingnome
Oct 20, 2014 12:25 PM
91 7three
Oct 15, 2014 12:57 PM
