48re Tranny broke!!! HELP!!!
Old Aug 24, 2011 | 12:01 AM
oberon1974's Avatar
ATTN 48re Tranny broke!!! HELP!!!
So........ I got into my truck, started it up, let it warm up for a bit, put it in drive, stepped on the gas a little, and started to pull away when...... it just gave up forward motion altogether. I have never felt it slip or shudder in its life except for the standard governor solenoid prob. I was able to creep it out of the way by turning off the engine, waiting a twenty count, restarting, and feathering the throttle for 5 - 10 feet of progress!! I had to do this at least forty times to nurse it into a parking spot!!! I dropped the pan, changed filter and fluid, started it up and drove a half mile or so and then bang, same **** thing. so i did the same on/off dance to get it parked again. Then i changed filter, gov solenoid, fluid, and cleaned and checked entire valve body. Bolted it back together and now i have reverse but no forward movement at all. doesnt even catch when you shift it into drive. Truck and tranny are mildly modified; ie. bully dog, exhaust, airaid, triple disc, billet shaft, trans valve body modified, etc. been running same combo for long time with no prob. What is going on? is it the torque converter? And if so why do i have reverse? PLEASE HELP!!
Old Aug 24, 2011 | 12:18 AM
12vcummins96's Avatar
sounds like its in the valvebody was there any metal in the pan
Old Aug 24, 2011 | 12:38 AM
oberon1974's Avatar
the first two times, there seemed to be very little, and no real burnt smell either, but ive dropped it again since and there seems to be alot of fine black residue covering much of the internals but still no burnt smell.
truck only has 85,000 miles, oh and magnet seems to have collected a fair portion of the black residue.
Last edited by oberon1974; Aug 24, 2011 at 12:38 AM. Reason: Automerged Doublepost
Old Aug 24, 2011 | 07:51 PM
Budgreen's Avatar
pretty sure the black residue is band and or clutch material. something happened and burned it up is what it sounds like.
Old Aug 25, 2011 | 08:34 AM
thats converter material
Old Aug 28, 2011 | 03:27 PM
oberon1974's Avatar
i was wondering if it might be torque converter, but my reverse still works. if it was converter wouldnt my reverse be gone too?
Old Aug 28, 2011 | 03:44 PM
sounds like you might have stripped your direct drive planetary
Kfohne21
10
May 12, 2022 10:13 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
