need help cummins 24 valve missing after load
Old Aug 21, 2011 | 09:25 PM
tirzoerik's Avatar
Default need help cummins 24 valve missing after load
engine mises than works fine here and there weird
Old Aug 21, 2011 | 10:47 PM
Red_Rattler's Avatar
High Tech Redneck
Stock? Milage? Valves ever been adjusted? Fuel issues? Any odd colored smoke when it does it?
Old Aug 22, 2011 | 02:34 AM
H.R.D's Avatar
I would say injector. An easy way to check it is get a temp gun and point it to the exhaust manifold and see which cylinder is the coldest.
Old Aug 22, 2011 | 07:01 AM
tirzoerik's Avatar
THE TRUCK IS 99 2500 STOCK HAS 280K AUTO SOUNDS GOOD MOME 10 TO 15 MINUTES THAN AFTER WARM IT WILL ALL SUDDENMISS FOR 3 SECONDS THEN RETURN TO NORMAL I REPLACED THE THE ELECTRIC PUMP UNDER BODY RAIL BUT SAME THING
ALSO NO SMOKE IF ANY BLACK
Old Aug 22, 2011 | 11:20 AM
aguilar_15's Avatar
TPS? Any codes?
Old Aug 26, 2011 | 01:52 PM
1 slow cummins!'s Avatar
I had the shop replace my lift pump once but after that it missed often... It was sucking air. Pull your filter housing off see if its bubbling at all?
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
PeteBug
Jun 11, 2015 12:16 PM
river rat
May 18, 2015 05:04 PM
Bigsexyhick
Diesel Engine Conversions
Mar 19, 2015 09:57 PM
Diesel combi pete
Nov 16, 2014 12:26 PM
