Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
l.e.d lights in '08 ford
Old Aug 18, 2011 | 05:11 PM
farmerdude's Avatar
Default l.e.d lights in '08 ford
Just put all clear lens l.e.d.'s on my flatbed. 4 oval stop/turn/tail's,4 oval clear b/u,2 amber marker,and 2 red marker.(btw, they look outstanding) I knew that the turns were going to blink too fast because l.e.d.'s don't pull enough juice. So went to NAPA,bought a grote l.e.d. flasher I went to put the S.O.B in and cannot find the O.E.M flasher. If anybody can help it would be much apprieciated?
Old Aug 18, 2011 | 05:15 PM
H.R.D's Avatar
I think it is a module that blinks the blinkers not a relay or a flasher tube. I know on the 3rd gen dodges you have to wire resistors inline to get them to work properly. I'm thinking the same with yours.
Old Aug 18, 2011 | 07:21 PM
farmerdude's Avatar
mad
Makes a guy wonder why in the hell,they have a part no. listed for a flasher for that model truck? Thanks for the info. I've known several dodge guy's that have had hell with theirs was hoping it would be a plug'n'play fix.
Old Aug 18, 2011 | 07:53 PM
joebob3093's Avatar
Moderator
Default Re: l.e.d lights in '08 ford
Retro solutions have a resistor you can install to cure that. I just bought a couple last night.
Old Aug 18, 2011 | 10:08 PM
farmerdude's Avatar
How big of a Pain in the **** are they to install?
Old Aug 18, 2011 | 10:14 PM
joebob3093's Avatar
Moderator
They come with scotch locks or im guessing you can do it the right way and splice them in with head shrink and but connectors
Old Aug 18, 2011 | 10:20 PM
H.R.D's Avatar
I would use shrink tube and solder, don't use butt connectors they don't make a good connection plus they add more resistance. Just my .02 cents.
Old Aug 19, 2011 | 04:25 PM
farmerdude's Avatar
Thanks,guy's for the good info. I'll see what I can get done.
Old Sep 19, 2011 | 08:45 PM
farmerdude's Avatar
well i talked to the guy that built my bed.He sent me to the local ford dealer. 10 min.,and a little reprograming later PRESTO! No flasher,no wiring in resistors,no problem. So if you guy's do L.E.D lights take it to your dealer they can fix the "fast flash".
Old Nov 12, 2011 | 07:55 AM
DAFBFD58's Avatar
Just fyi the ford relay is tucked up under the dash behind the center part. Its pita to get but its there.
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
Nov 4, 2014 01:30 PM
Oct 14, 2014 08:40 AM
