Bad MPG'S
Old Aug 17, 2011 | 12:38 AM
posmx's Avatar
Default Bad MPG'S
i have a 99 f250, 6'' lift on 35x12.50x16.5 tires, cold air intake, 4'' turbo back, edge evolution chip, runs great but only gets 13mpg.
what can i do to get better mpgs? friends with the same trucks mildly modded on same size tires are getting 18+ mpg...
thanks
Old Aug 17, 2011 | 01:09 AM
Default Re: Bad MPG'S
What kind of shape is your hpop in?
Luke
Old Aug 17, 2011 | 06:42 AM
riddick01's Avatar
when was the fuel filter last changed. i bought my truck new (same thing as urs only on 36" tires and a ts chip) and was at 14...now im closer to 17
Old Aug 17, 2011 | 07:32 AM
95powersmoker's Avatar
Take the lift off, put stock tires back on and take the Edge off...
Old Aug 17, 2011 | 09:14 AM
PHPDiesel's Avatar
Sponsor
thanks
Sounds about right to me. Besides, with a status that reads, "new truck needs some power", it appears that mileage shouldn't be a concern. You will NEVER get more power and better mileage at the same time. Pick one or the other and accept it for what it is.
Aftermarket intake and exhaust do NOTHING for mileage so that's a null point.
As stated, take off the lift and the wide tires. The tuning on the EVO is not hurting your mileage (unless you can't keep your foot out of the accelerator pedal at which point NO other brand of tuning will help your mileage) so no issues there.
I highly doubt your friends are getting 18 MPG with similar trucks and tires.
Old Aug 17, 2011 | 12:28 PM
posmx's Avatar
What is hpop? I just got the truck so I'm not too sure about the fuel filter. And my friends have 4" lifts, but run the same size tires.
Also, the 'new truck needs more power' is for a. Stock 1996 12valve I bought
Old Aug 17, 2011 | 01:40 PM
joebob3093's Avatar
Moderator
Hpop is the high pressure oil pump. Change the fuel filter and see what it does. What gears do you have what gears do they have?
Old Aug 17, 2011 | 03:49 PM
1999stroker's Avatar
I got a late 99 ext. Cab 4x4.stock except tires and exhaust. I started out at like 11 MOHs roughly not including tire size difference
Old Aug 19, 2011 | 01:54 PM
CSIPSD's Avatar
Your milage is fine for a truck on 35's...
|WYG|SS
Jul 4, 2015 08:31 AM
Dustin M
May 21, 2015 10:19 PM
Feb 5, 2015 12:10 AM
Alex Buchanan
Dec 20, 2014 08:45 PM
12vbomber
Nov 11, 2014 10:58 AM
