keeps losing prime?!?
Old Aug 15, 2011 | 08:26 AM
ebarresi5894's Avatar
Default keeps losing prime?!?
hi, i have a 95 2500 6.5L TD VIN F.
i did the fuel filter a few days ago, read how to do it (fill bowl, let it purge etc)
it ran fine, then the next morning it ran for 30 secs and died. re purged it and it ran all day if i didnt shut it off. let it sit for 2 hours and did the same thing.
proper way to bleed or idk?!?
thanks in advance guys
Old Aug 17, 2011 | 11:07 AM
Crazy's Avatar
If you are still loosing prime you have leak or sucking air from some where
After running all day or just few mins it should prime it self
Look in the engine valley but fuel housing see if there fuel in the valley
Old Aug 19, 2011 | 02:24 PM
konstan's Avatar
In my case the problem was the fuel shut off solenoid. Not only it was losing prime, it was also leaking when idling; the leaking diesel ends up dripping from the hole in the transmission bellhousing. New FSOS fixed that.
Old Aug 21, 2011 | 12:26 PM
i put a new lift pump in, and it helped, yet it was still doing the same thing.
idk if its primed the wrong way or what, but i also found a leak in the fuel lines, that i fixed. it runs great, esp, with the new turbo-master that i got
except when i punched it it started bucking, farting and wanted to die, and it took about 30 secs of idling before i could drive it normal again.
WTF COULD THAT BE?!?
the pmd had been moved, new lift pump, new fuel filter, idk what to do
Old Aug 21, 2011 | 03:32 PM
Crazy's Avatar
what is your Boost running at
Did take the PMD of IP and if so how many miles on PMD and are you getting any codes
Old Aug 21, 2011 | 04:44 PM
nope im not getting any codes, and the pmd is on the firewall
and i have the boost set to 5-7psi w/ the turbo-master at 2.5".
but it has been doing this for a while..
Last edited by ebarresi5894; Aug 21, 2011 at 04:44 PM. Reason: Automerged Doublepost
acj
9
Dec 26, 2015 09:54 PM
NSmachine44
Aug 16, 2015 09:25 PM
Baradium
Mar 9, 2015 07:15 PM
06powerstroke
Feb 24, 2015 07:52 PM
Jrebyank
Feb 15, 2015 07:57 AM
