99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
turbo size
Old Aug 14, 2011 | 11:48 AM
7.3 Ranger's Avatar
Default turbo size
ok so im starting to build a 7.3 right now , im just wondering what turbo to run i know where i can get a brand new HX 50 for 100 anyone now if i will be able to spool it or not . thanks
Old Aug 14, 2011 | 11:54 AM
cummin_un_glued's Avatar
FormerVendor
nope hx50s are hard to spool with a fair amount of fuel, i'd say near impossible on a 7.3 without tons of work
Old Aug 14, 2011 | 12:10 PM
7.3 Ranger's Avatar
oh ok what should i be looking at to get then ?? im looking to make around 450 to 500hp , im just starting to build this engine right now , im new to the diesel world or could i use the stock turbo and the hx 50 together would that work
Old Aug 14, 2011 | 12:47 PM
FormerVendor
compounds are not easy to build on a 7.3 ie nobody makes a kit so its all one off fab work
for 500hp a single 66mm charger will get you there and can be built from a stock 7.3 charger i dont know the exact price because its been over a year since the last one that we had built but i can get you a price tomorrow
Old Aug 14, 2011 | 01:16 PM
7.3 Ranger's Avatar
ok thank you
Old Aug 14, 2011 | 03:58 PM
joebob3093's Avatar
Moderator
Default Re: turbo size
A stock turbo will not support 500hp. For that you will want a modded H2E, GQSSB, GT42, S400 or something in that range.
Old Aug 14, 2011 | 05:16 PM
FormerVendor
those are some large turbos what turbo are you running joebob?
Old Aug 14, 2011 | 05:35 PM
joebob3093's Avatar
Moderator
You have to remember the powerstroke is alot bigger then the cummins so they will spool alot larger turbos. The ones I mentioned are not that big and work great for the 500hp range. Empire makes a compound kit and I know WOP and maybe black widow can build you a kit. Right now im running a stock turbo but soon im going to be running an S366.
Old Aug 14, 2011 | 09:52 PM
FormerVendor
yeah i know a powerstroke can spool a larger turbo because of the larger displacement but the stock charger is doin good to make 25psi also
to me if your staying >66mm on the compressor theres no reason to go to that large of a frame on the turbo (S400)
tell me what the advantage of a S366 would be over a stock charger with a ebpv delete housing and a 66mm compressor wheel
Old Aug 14, 2011 | 10:11 PM
joebob3093's Avatar
Moderator
I don't understand any of that.
