electrical problem... Help me please!!!
Old Aug 6, 2011 | 03:06 PM
famousstarsnbars's Avatar
Default electrical problem... Help me please!!!
Well i have an old 86 ford f250 that wasnt starting unless the batteries were on the charger. So i bought 2 new batteries and a new alternator and voltsge regilator because it wouldnt keep the batteries charged now after starting the truck and unplugging the batteries to test the alternator it says its putting out high power but when i plug the batteries back in it drops way low on the guage. Any ideas? Thank you
Old Aug 6, 2011 | 04:16 PM
DieselCrawler's Avatar
never trust the factory gauges for one.
get a multi meter and see what it is charging at when the truck is running.
Old Aug 6, 2011 | 04:20 PM
I have an aftermarket tester it says 14 volts when the cables are off the battery 12.5 when theyre on
Old Aug 8, 2011 | 05:20 AM
u should never run it without the cables hook to the battery. can fry the voltage regulator and or the alternator.
and so with the wires hooked up, you are only seeing 12.5 volts at the battery?
Old Aug 8, 2011 | 09:55 AM
Ok i wont do that anymore but yeah its lmly 12"volts at the battery
Old Aug 8, 2011 | 04:57 PM
does it raise when you rev it?
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
moparman70
Jul 30, 2015 12:38 AM
Dadslb7
Dec 9, 2014 11:05 PM
signoremint
13
Oct 21, 2014 07:21 PM
