03 duramax
Old Aug 2, 2011 | 05:40 PM
dreese's Avatar
Default 03 duramax
I have a 2003 duramax lb7. I got fuel about a month ago and it had water in it. It started missing really bad and sounded like it was knocking. I changed the fuel filter and a week later it started doing it again So I changed the filter again put injector cleaner in it and water dry for diesel. It has been running fine until the other night I started doing it again. I came home drained took the plug out where you drain the water out. Its running fine now but what could be causing this?
Old Aug 2, 2011 | 06:57 PM
cummins freak's Avatar
you buying fuel at the same place everytime? If so maybe try a different shop?
Old Aug 2, 2011 | 07:36 PM
dreese's Avatar
I have bought it from 2 different stations since then.
Old Aug 7, 2011 | 12:50 PM
2500HeavyDuty's Avatar
checl the oil and see if it smells like diesel, does the idle fluctuate at all?
the knock noise your describing, its it like a loud tap that responds to the throttle?
Old Aug 9, 2011 | 05:39 PM
dreese's Avatar
It idles fine. It was cutting out and start knocking when I would drive down the high way at 55 or 60 mph.
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
Dec 3, 2014 08:10 AM
