Chevy/GMC Duramax 2011 LML Discussion of Chevy and GMC Trucks with LML Duramax Turbo Diesel Engines
Vented Tip???
Old Jul 31, 2011 | 02:09 PM
CoalTrain99's Avatar
Default Vented Tip???
Do you have to run a vented tip on the new Duramaxs, if it still has dpf filter?
Old Aug 1, 2011 | 10:36 PM
BriteWhiteRam's Avatar
no.... its just to prevent burns to your legs
Old Aug 12, 2011 | 10:51 PM
1993firstgennewbie's Avatar
YES if you dont your truck will probly light on fire and explode AND YOU WILL DIEEEEE!!!!!!!!!
Old Aug 12, 2011 | 11:01 PM
redneckpipeliner's Avatar
I thought the point of the vented tip was to mix clean air with the diesel smoke to make it look not as dark, for all the activists. Cheap and easy way of making it not as noticable, out of site out of mind.
Old Aug 13, 2011 | 09:18 PM
NO ITS TO KEEP THE TRUCK FROM EXPLODING YOU HAVE TO GET A FLUX CAP TO FIX IT IF YOU WANT TO TAKE IT OFF
Old Aug 14, 2011 | 08:50 AM
done trolling?
the vented tip keeps the tailpipe cooler due to high temps created by regens, if you delete all the dpf/emissions then the vented tip is no longer useful, but if you go that route you no longer have a warranty
Old Aug 18, 2011 | 11:06 AM
sorry i was borred you can take that big whale d1ck off it doesnt do any thing
Old Feb 7, 2012 | 02:35 PM
H.R.D's Avatar
Originally Posted by 617.95
The warranty of the emissions system will only be affected. The engine, drivetrain and chassis warranty will NOT be affected.
On Fords and GMs.....no such luck on a Dodge
Old Feb 7, 2012 | 04:05 PM
H.R.D's Avatar
Good luck fighting a Cooperation on that...
What do you make of that? Not trying to be an *** just interested.
Souce: Wikipedia
Old Feb 7, 2012 | 04:32 PM
H.R.D's Avatar
Okay but running a truck with out a factory installed DPF/EGR is consider unreasonable use. It's against the law....
