EGT gauge wiring
Old Jul 29, 2011 | 10:31 AM
POWERSTROKEMANIAC's Avatar
Default EGT gauge wiring
I just got my EGT gauge. But the instructions on wireing are too confusing to understand. Could anyone tell me what to wire this thing to? It says one wire goes to a 12V constant power source (fused) and one to a switched 12V power source?
Old Jul 29, 2011 | 10:49 AM
CSIPSD's Avatar
Depending on the manufacture...
You need a constant hot (as in the battery or using a probe find a wire under the dash that is hot all the time) for the constant.
You need a key on power, meaning find a wire with a probe that is only on when the key is in the run setting.
You need a ground (there may be one for lighting and one for the gauge itself-these can both be run together).
You need to tap the dimmer switch for the lighting circuit...
Old Jul 29, 2011 | 03:19 PM
Thanks I got it. What should my egt be safe around? I an running a ts 6pos
Old Jul 29, 2011 | 06:02 PM
95powersmoker's Avatar
Just cruising, 5-700. Keep 1250 in the back of your mind as a number not to exceed for anything more than short blips...
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
12valve_soot
Nov 12, 2014 10:02 PM
