94 psd diesel starts then dies?
Old Jul 20, 2011 | 09:14 AM
justanother92's Avatar
Default 94 psd diesel starts then dies?
Hey i have a friend that just bought a 1994 psd 5spd. It had been sitting for about 5 years with very little use. It ran fine for the first day and then started acting up. It will start every once in a while and may run for 1 minute or 10 seconds and just shuts off like you killed the power. The fuel bowl is full and the lift pumps seems to fill it fairly quick. And yes we changed the fuel filter. We changed out the power box on the DS inner fender and that did not do anything. Has 180000 miles and seems to be in good mechanical shape other wise. Any ideas would be greatly appriciated! Thanks Chad.
Old Jul 20, 2011 | 11:48 AM
CSIPSD's Avatar
Dump all the fuel out of the tank, replace with new.
Hope you didnt *** up the injectors with bad fuel.
Have you checked the oil? Changed it?
Check the HPO res level as well.
Old Jul 20, 2011 | 05:50 PM
He changed the oil shortly after he got it. He added a can of seafoam to each tank, and when it runs it sounds great does not miss or smoke. i will check the oil in the hpop. It just is really strange how it up and quits just like you turn the key off. Could the cam sensor possibly cause problems?
Old Jul 21, 2011 | 12:24 PM
85_305's Avatar
Being Evaluated
Diesel takes a LONG time to go bad and is often stored for 15-20 years and still isn't bad, I highly doubt thats the cause of the issues.
Old Jul 21, 2011 | 01:33 PM
joebob3093's Avatar
Moderator
Default Re: 94 psd diesel starts then dies?
Never run sea foam. It take all the lubricity out of the fuel and will destroy your injectors.
Old Jul 21, 2011 | 01:37 PM
85_305's Avatar
Being Evaluated
Seafoam is petroleum based and is lubricative.. I've used it on a few diesels and lots of gassers. Seafoams website even has a section answering questions on diesels and says it's safe
Old Jul 21, 2011 | 04:12 PM
joebob3093's Avatar
Moderator
You go right ahead. I will never run it in mine.
Old Jul 21, 2011 | 04:24 PM
85_305's Avatar
Being Evaluated
I've done-so many times.
Sea Foam | Diesel Engine FAQ's
Old Jul 21, 2011 | 05:56 PM
So do you guys think it might be the cam sensor causing the problem? when i hook the scan tool up it just says vehicle not responding. I talked to a ford mechanic and he said that it probably had not been reprogramed to scan.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
Apr 15, 2015 09:40 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
