Factory block differences?
Old Jul 19, 2011 | 05:58 PM
J-Pipes's Avatar
Default Factory block differences?
I was wondering if dodge used different blocks for 2wd to 4wd trucks? Wondering if they are different, could the potentially shorter 2wd blocks be used to slightly lower a 4wd? Are there any differences in spring width from 2500 to 3500? Oh, I'm talking about the factory slavery block between the leaf springs and the perch on the axle.
Sent from my PC36100 using Tapatalk
Old Jul 21, 2011 | 07:11 AM
J-Pipes's Avatar
Default Re: Factory block differences?
Anyone? I'm asking about 2nd gen 94-02 specifically.
Old Jul 21, 2011 | 07:34 AM
biged681985's Avatar
the 4wd uses a 4 inch block in the rear, the 2wd doesnt use a block.
Old Jul 21, 2011 | 08:01 AM
J-Pipes's Avatar
Ok thanks, could a 2" or 3" lift block for a 2wd be used to lower the rear of a 4wd?
Old Jul 21, 2011 | 08:04 AM
J-Pipes's Avatar
Or where could I find info on lowering the rear of a 4wd about 2"?
Old Jul 21, 2011 | 08:49 AM
if you can find a 2 or 3 inch block it can be used as long as it aint a cheap one from a parts store. seen to many of those break. im planning to drop mine a full 4 inches and 2 in the front eventualy, but only doing 2 of it right now. should have some pics next week of it 2 lower in the rear
Old Jul 21, 2011 | 10:08 AM
J-Pipes's Avatar
Cool thanks, post the pics when you get it done. My truck has leveling coils in the front now, and I want to keep the "leveled" look but would like to drop it back to stock springs in the front, then drop the rear to even it back up. Reasoning is right now it is just a bit high when hooking trailers, and if I lower it a little I could run slightly smaller tires, have the same look, get more power to the ground, and hopefully cost less to replace, and I was hoping that lower to the ground and smaller tires should boost mileage as well.
Old Aug 4, 2011 | 06:45 PM
J-Pipes's Avatar
Got my truck lowered down today, factory coils in the front, and went from a 4-5/8 factory block to a 2" block in the rear. Try to post a pic, has 285/75/16 tires on stock wheels.
Old Aug 5, 2011 | 01:38 PM
looks good man. i ended up having to put the 4 inch blocks back in mine till i get new u-bolts
Old Aug 5, 2011 | 06:48 PM
J-Pipes's Avatar
Thanks, I'm checking into airbags now, pretty sure when I hook up the heavier loads, its going to look kinda saggy.
