83 chevy to cummins help?
Old Jul 18, 2011 | 11:43 PM
94Cumminz's Avatar
Default 83 chevy to cummins help?
i found a 83 chevy dually 4 door 2wd for 800 but the ball bearing broke and the A frame is bent, is it worth 800 or not and how hard would it be to make it 4wd and swap a 93 cummins motor in it? any input would help
thanks
Zac
Old Jul 19, 2011 | 02:20 PM
cumminsf150's Avatar
what do you mean ball bearing? it would be easy to convert to 4wd if cutting off all the front suspension and fabricating your own front suspension for a solid axle swap is something you are comfortable with. if you can handle the 4wd conversion getting the engine in it shoud be easy.
Old Jul 19, 2011 | 02:26 PM
94Cumminz's Avatar
i think the bearing in the axle went out and bent somthing. idk i need to call the guy and see
Old Jul 20, 2011 | 09:15 PM
Dirtclod's Avatar
Mine is an 81 crew cab long bed 1 ton, I put the 4 wheel under it, with a 24v. I'd do it again in a heart beat.
Old Jul 24, 2011 | 06:48 AM
andrewmp6's Avatar
Its easy to swap to a 4x4 you just need one for parts.Look around on 67-72chevytrucks.com there is a few trucks like that on there done.
Old Jul 24, 2011 | 10:00 AM
bobfbigman's Avatar
Most likely a "ball joint" failed and bent an A-arm on front suspension
Old Jul 24, 2011 | 11:43 AM
2MuchJunk's Avatar
I don't thing there is anything difficult about making a 80's Chevy 4wd or swapping in a Cummins. It kind of depends on your ability's. If you have mechanical ability, can weld and fabricate then go for it.
DieselDan370
Aug 23, 2016 02:24 PM
Big Sal
Apr 19, 2015 03:59 PM
Oct 31, 2014 08:10 AM
Oct 16, 2014 07:10 PM
mtedrick4
Oct 13, 2014 09:25 PM
